just wondering if its possable to swap ecu for one wi a different code,still from a 325i of course,I only ask this as my ecu has had a habit of frying some chips in the past
any info would be greatly appriciated
cheers tam
ecu swap
rosscoe
bottlecapE30
I had the same question awhile ago and if the numbers are different then no. there where many types of ecus for the 325i and you would be better off finding the right one then messing things up using the wrong one. Even if it did work the fuel and spark maps will be off. hope this helps.
1987 2.7l e30 m20b27 supercharging
1991 3.5l e30 m30b35 it is dead so sad
1985 3.5l e23 m30b35
