does mtec2 have a kat???
chariot
Post Sat Jul 15, 2006 6:32 am
recent owner of an 89 mtec2. anyone advise how can i tell if it has a catalytic converter or not??? vin # ae53258 and order discription for the car does say 'katalysator-entfall'- is that the kat? thanks
E30Mark
Post Sat Jul 15, 2006 9:25 am
Have a look under the bonnet, feel up under where the battery would be if it was in the front. Under there you will find a wiring connector, if it's blanked off, then you don't have a cat. If there is another wiring loom plugged in going down to a lambda sensor then you have a cat... rip it out! :cool:
PM for details
reggid
Post Sat Jul 15, 2006 2:29 pm
E30Mark wrote:If there is another wiring loom plugged in going down to a lambda sensor then you have a cat... rip it out! :cool:
the kat or the O2 sensor...lol?
E30Mark wrote:Have a look under the bonnet, feel up under where the battery would be if it was in the front. :cool:
Wouldn't it be better to look under the car see if there is a kat?
dazleeds
old skool raver
old skool raver
Post Sat Jul 15, 2006 2:53 pm
EITHER OPTION WILL TELL YOU
THE LAMBDA plugs into a socket under the battery tray in the front
so its a bit easier to check than crawling about the floor lol
under batt tray youll feel a big round plug
if theres nothing plugged into it then there aint no cat :D
www.oldskoolfantasy.co.uk
E30Mark
Post Sat Jul 15, 2006 7:33 pm
If you know what a cat looks like....
PM for details
Chris-W
Post Sat Jul 15, 2006 7:34 pm
(Insert obvious "4 legs, tail & whiskers" joke here)
chariot
Post Sun Jul 16, 2006 1:49 am
Thanks quys, much appreciated :D
