e36 clock/date set.HELP!
bmpaul
Post Mon Jul 10, 2006 12:09 pm
there should be two buttons press the one with the + sign untill the time is right
E39 530d M-sport- quite nippy
stuartgallafant
Post Mon Jul 10, 2006 1:02 pm
has it got obc? if so, there's two versions... basic and full! on each of them there is 4 buttons, labelled 1000, 100, 10 and 1. use these buttons to set the time.
if i remember correctly, you select the time display whilst ignition is on, then trun off ignition, hold 'reset' and trun on ignition, and then use the 4 buttons.
hope this helps! let me know if it doesnt, and i'll go and look at one of the cars outside. we must have an E36 here today...
stuartgallafant
Post Thu Jul 13, 2006 10:44 pm
did this help???
stuartgallafant
Post Sun Jul 16, 2006 12:02 pm
i take it it worked then....
