Gear linkage
Rich25i
Post Thu Jul 06, 2006 5:42 pm
Hi is the 5 series E34 linkage the same as an E30 one or what bits are the same?
I can get a complete new linkage but its for a manual 3.5 car. bloke wants pennys for it so worth a shot
Thanks in advance
RICH
DRIFTBOY
Post Thu Jul 06, 2006 6:12 pm
Hi!
The E30 linkage is quite a bit shorter than the E34 one. They will fit on each other's gearboxes but will put the gear lever in the wrong place.
It is possible to cut and weld but they are aluminium so require TIG welding.
charlE30
Post Thu Jul 06, 2006 7:03 pm
Rich you might be OK with a standard E30 325 linkage, I haven't modified mine but it has shifted the shifter back about 8-10mm, I can still select all gears without it fouling anything :D
Would this bloke happen to have a 535 middle box/downpipes he'd like to sell :wink: if you wouldn't mind asking him I would be eternally grateful :cool:
Cheers dude
Charlie
BMW F31 335d xdrive
Andy335Touring
Post Thu Jul 06, 2006 10:20 pm
If you need both 325 linkage bits i think i've got a set
ed325i
Post Thu Jul 06, 2006 10:53 pm
I had to shorten my E30 one. The bit of wood in the pic was replaced by 2 bits of metal either side which sit in the groves and was just bolted together.
ED
stevetigger
Post Thu Jul 06, 2006 11:27 pm
Why shorten and have the possible problem of twist, when you could get the E36 item! winkeye
Rich25i
Post Fri Jul 07, 2006 12:33 pm
Thanks for your replys.
Very helpful
Im not sure if the exhaust is on the car but i will let you know if it is when i see the car next.
Once again thanks
