f***ing speedo
bultjeboo
Post Mon Jul 03, 2006 12:16 pm
hi, can anyone help ive tested all the wires in the little loom at the back and the main loom i've reolaced the cluster (i know this works i've seen it in action) and the f**ing thing still wont work. could it be the relay (has any one got a list of what relay/fuse does what)?
Im carless, BUT, hope to remedy that fairly soon, plus, need to actually be able to drive first so that gets priority!!
cliffybabe
Powered by Nelly
Powered by Nelly
Post Mon Jul 03, 2006 12:27 pm
Fuse layout
Fuse Rating Description
1 7.5 Headlight, left high beam
2 7.5 Headlight, right high beam
3 15 Aux. cooling fan, low speed
4 15 Turn signals
emergency flasher
Active Check control
Digital Clock
5 30 Windshield wiper and washer
6 7.5 Stop lights
Cruise control
Active check control
ABS
Interior lights
7 15 Horn
8 30 Rear defogger
9 15 Fuel delivery
Idle speed
10 7.5 Seat belt warning system
Service interval indicator
Tachometer/fuel economy gauge
Instrument gauges and indicators
Brake warning system
Back-up lights
OBC
Starter
Fuel delivery
Idle speed
Stop lights and cruise control
11 7.5 Fuel pump
12 7.5 Radio power
Speedometer/instrument indicators
OBC
Multifunction Clock
13 7.5 Left Low Beam
14 7.5 Right Low Beam
15 Not Used
16 15 Heated Seats
17 30 Sunroof
Power Windows
18 30 Aux. cooling fan, high speed
19 7.5 Aux. cooling fan
Interior lights
Power mirrors
20 30 Heater/Air conditioner
Auxiliary Radiator cooling fan
21 7.5 Glovebox light
Flashlight
Ignition Key/Seat Belt warning
Interior Lights
Radio Memory
Trunk Light
Active Check Control
Service Interval Indicator
OBC
Fuel deliveryTachometer/Fuel Economy Gauge
Digital Clock
Multi Function Clock
22 7.5 Active Check Control
Front Parking Lights
Taillights
Front Side Marker Lights
23 7.5 Instrument Panel Lights
Taillights
Rear Side Marker/License Plate Lights
Rear Defogger
Multi-Function Clock
OBC
24 15 Turn Signals
Emergency Flasher
25 Not Used
26 Not Used
27 30 Interior Lights
Central Locking
OBC
Radio Amplifier
28 30 Lighter
Power Antenna
29 7.5 Left Fog Light
30 7.5 Right Fog Light
See also: "Relay layout in the Power Distribution Box"
stuartgallafant
Post Mon Jul 03, 2006 12:51 pm
how very helpful of you Neil!!!
girls, have you tested resistance across the pick-up sensor for the speedo? the white bit that the connector plugs into? sometimes these fail, which would obviously cause loss of speedo
however, checking the fuse is a priority, as my mate spent about £90 trying to fix an inop speedo, when all it was in the end was a fuse he'd blown when installing his radio!! numbnut :mad:
cliffybabe
Powered by Nelly
Powered by Nelly
[quote="stuartgallafant"]how very helpful of you Neil!!!
quote]
See im learning :cool:
stuartgallafant
Post Mon Jul 03, 2006 12:54 pm
glad to see it mate!!
you're a master with the electrics anyway!!!
cliffybabe
Powered by Nelly
Powered by Nelly
Post Mon Jul 03, 2006 12:59 pm
stuartgallafant wrote:glad to see it mate!!
i take that as a compliment coming from a professional such as yourself (seriously)
stuartgallafant
Post Mon Jul 03, 2006 1:03 pm
well from one professional to another, thank you very much...
PS: look neil, im a regular now!!! yay!
Pal318is
Post Mon Jul 03, 2006 1:20 pm
Check your conection on the diff, mine has come unstuck with the wether I presume, so could be that. To small wires that are conected to the diff, may well need to be reconected. But as the guys said, check your fuses too. 8)
Pal
Pal
Image[img]http://Image
colcabman
Post Mon Jul 03, 2006 3:06 pm
had that trouble myself a while back turned out to be the wire onto the sensor on the diff had broken,
