Early 325i engine on later management
- Homo Hair
Is it possible to run the earlier 2.5i (high compression) with the later engine management n loom?
randomdave325
- Random E30 Nutta
yes. you have to change the waterpump, front timing cover(for the crank sensor) plug leads and front pulleys,not sure about the inlet manifold. it should be the same. other that should be no problem.
The current fleet!
1990 318iS
1984 528ise
1987 325i sport
1990 325i cabrio
1987 m3 s50b30
'Turning money into noise'
cabrio327i
HI there Reardiffraver, just reading that you need to change the waterpump so that you can use the later 173 motronic, why is that then? i am doing the same swop so i can use a later sport gearbox, i know the two pumps are different, the later one not having the takeoff for early header tank on the offside wing, but i would not have thought this would be a problem. cheers dave
randomdave325
- Random E30 Nutta
.HI there Reardiffraver, just reading that you need to change the waterpump so that you can use the later 173 motronic, why is that then? i am doing the same swop so i can use a later sport gearbox, i know the two pumps are different, the later one not having the takeoff for early header tank on the offside wing, but i would not have thought this would be a problem. cheers dave
i was just speaking from what i had to do when i put an earlier engine in a facelift car. Jhonno did not state which way round he was doing it. i just assumed he was putting an early engine in a facelift car. if you are putting it in an earlier car you would not have to change the waterpump. but as you are going all the effort to switch to the later motronic. why not upgrade the cooling system too. it's obviously better or bm wouldn't have changed it. you only need a radiator, header tank, pipe work and a pump. all easily and cheaply avaliable from a scappy. sorry i should of made it clearer. hope this helps
The current fleet!
1990 318iS
1984 528ise
1987 325i sport
1990 325i cabrio
1987 m3 s50b30
cabrio327i
No problem mate, see what you mean, all clear now cheers dave
