i really need to change mine now as its terrible to drive smooth
i like the idea of solid but a nice new one would do too
are they easy to do . or is it a press in and out job?
diff bush
psychochild187
Ziggy
Get the m-coupe one - £20/£30 ish from the dealer though IIRC.
Easy enough to do yourself, just release the old one by cutting through the metal part with a hacksaw, then I think I just tapped mine in with a mallet...
syncro
is there a part number for this m coupe diff bush? does if fit both large and small case diffs?
badboy007
hi sorry to go a bit off topic here but im fitting a 3.73 lsd to my cab sometime this weekend the bush on the donor diff seems ok, would you reccomend i change it and are they common to go? because seen as tho the diff is off might as well get one put on to save hassle in the future, is the m-coupe bush stronger or something?
cheers
cheers
- Homo Hair
for the price of a new one.. might as well change it whilst its out imo unless the one in there is nearly new
