Guys I just found out my car driven at constant speed of 80Mph for half an hour suddenly develops slight hesitation. When I slow down to 70Mph it runs fine.
Could this be a fuel supply problem. I am thinking to buy a PBV http://www.fuelsystem.co.uk/pbv.htm
Do you guys think this should solve my problem?
Or am I looking at changing my aging fuel pump?
any ideas?
tnx
E30 325i slightly hesitant at 80Mph constant speed !
Ant
- Retired Team Member
Do you have a cat and 02 sensor fitted ?
if so the 02 feedback could be leaning the car right back on cruise hence the lean feeling hesitation/flat spot, has been described as a small stutter too in the past.
Avoid those "boost valves" like the plague, 1.7:1 rising rate= overfuelling on accel, and everywhere else dude
Email FTW
haffeel
Yes I do have an O2 sensor, but no CAT .
Ant thanks for the reply mate, the last time I did ask you, have you taken in to consideration the O2 sensor when programming the ZONE CHIP you sent me. You said some thing now I cant remember well
So what shall I do?
tnx ANT
So what shall I do?
tnx ANT
Ant
Remove the 02, bung the hole and try again
Email FTW
haffeel
thanks, I will post my reply after a couple of days time when I have tested. Oh yes thanks for the no cost solution
regds/haffeel
regds/haffeel
