325i Cam timing
Templ8e30
Post Mon Mar 07, 2005 10:13 am
I'm installing a new cam this afternoon and will be degreeing the cam but cannot find the spec anywhere :cry:
Does any body know what the standard cam timing is ?
Cheers :cool:
Iain T
M3GTR
Post Mon Mar 07, 2005 1:18 pm
If it is a standard cam, it doesn't need degreeing up unless you are using a different pulley. If everything is standard, just make sure that the marks all line up (and youaren't 180 degrees out) before adding the belt.
