hi.. can anyone help, am intending to put a 325i engine into my 320i car and attach it to the 320i gearbox... will my 320i clutch fit or will i need a 325i clutch?
would a 325i clutch fit in a 320i gearbox???
thanks in advance
320i clutch into 3251???
stonesie
I just had a look on GSF and the part numbers for the 320 / 325 are different so i woould go with a new 325 clutch
Templ8e30
The 320i and 325i clutches look the same and have the same dimensions but the 325i model has a higher clamping force and will take more torque and power.
Fit a 325i clutch for peace of mind.
Cheers,
Iain T
Cheers,
Iain T
2007 Mazda 6 2.0 estate
So does that mean that flywheel, driven plate and release bearing are all the same, with just a different cover plate assembly?Templ8e30 wrote:The 320i and 325i clutches look the same and have the same dimensions but the 325i model has a higher clamping force
Iain T
Templ8e30
Indeed it doesBrianmoooore wrote:So does that mean that flywheel, driven plate and release bearing are all the same, with just a different cover plate assembly?Templ8e30 wrote:The 320i and 325i clutches look the same and have the same dimensions but the 325i model has a higher clamping force
Iain T
Iain T
