Swapping to Kenlow....Help!
jonbuoy
Post Tue Jun 13, 2006 10:02 pm
Hi peep's,
Going to swap the viscious for the kenlow but a bit lost of where to start? :?
What fan will fit?
How does it attach?
Front or rear of rad? Preferably front.
Going to put a seperate switch aswell as the fan coming on automatically but do i just wire into the wiring to the sensor?
Has anyone else done this before?
This conversion will be on M20 B25.
Any help appreciated :cool:
jonbuoy
Post Sat Jun 17, 2006 9:14 pm
Still need to sort this as she get's quite hot when drifting winkeye
Post Sat Jun 17, 2006 9:36 pm
I used an E32 aircon fan on mine, just about fits in the gap! Very quiet on low speed, you hardly notice it running, but high speed moves a serious amount of air! Would cool down the hottest of engines.
I personally would only put a manual switch into the high speed side of the temp switch wiring.
If you dont have the hole in your rad for the temp switch then pm me and I can get you a T-piece made for the top-hose :wink:
