had a play today and i got to 118/119 on guage in my car
but she not standard so just wonderung how this compares
hmmmSteviec wrote:The speed you mention though is just the speedo reading, this could easily be way out at high speeds.
To check the speed you need to borrow a gps devise like a road angle that shows your accurate speed.
Why disconnect everything? Some tipex marks in the right places and jack it up, make sure the wheels turn at the same speed, probably better turnin the prop more than once then do the maths to get a more accurate reading cos thers not a lot of difference between those ratios when the props turned by hand if you know what I mean.jonbuoy wrote:I've just changed the engine in mine Daz to a 2.5 from a 1.8 M40.
Late 2.5 engine
2.0l manual gearbox
3.25 LSD
And mine does 120mph at 6000rpm in 4th
If you can't read the tag, as i could'nt, the only other way i know is to disconnect the prop and half shaft's, mark the output shaft, turn the input shaft one revolution and count how many time's the output shaft turn's.
Mine turned 3 1/4 turn's so that tell's me it's a 3.25 and you can feel it is as it take's a little longer to get to where you are goingbut the speed's you get are fantastic
