mot question?
tickle
Wed May 31, 2006 4:36 am
is it an mot failure if the front jacking points are removed
Cars and girlfriends have alot in common.
They both make you angry+ make you cry, bleed your wallet + moan when they are old.
But at least the car makes sense!
charlE30
Wed May 31, 2006 7:29 am
Do you mean the strange square things just behind the front wheel arch? if so they aren't really jacking points, they were used in the factory for moving the shell around. On my last MOT I needed them repairing, they just removed it and welded a plate in it's place so I would say in answer to your question, No it's not an MOT failure.
BMW F31 335d xdrive
Chris-W
Wed May 31, 2006 9:25 am
Just to confimr what's said above, as I've asked this specific question of an MOT tester.
tickle
Wed May 31, 2006 2:01 pm
good good, any news on the starage box's in the boot?
charlE30
Wed May 31, 2006 5:35 pm
Depends how bad the rust is and which side, in one of my old 325's there was a rust hole on the battery side and got an advisory from the MOT guy but it still passed. I think if it's close to the towing eye then they may fail it for obvious reasons, I could be wrong as I'm only guessing....
BMW F31 335d xdrive
Chris-W
Wed May 31, 2006 5:49 pm
charlE30 wrote:I think if it's close to the towing eye then they may fail it for obvious reasons, I could be wrong as I'm only guessing....
I think it's within 30cm of structural / chassis. And 'open sores' as well.
