Power steering rack install
eamo
Post Thu May 25, 2006 1:51 pm
my 320 has a manual rack which I have just removed. i have just got a pas rack with pump, resevoir and pipes
can someone tell me what if any other parts I need and how do i go about installing it? Any diagrams or writeups?
thansk
dazleeds
old skool raver
old skool raver
Post Thu May 25, 2006 1:54 pm
very easy to fit fella
reverse what you did to remove the manual rack
is everything still atatched to your new rack ?
ie res bottle pipes etc etc??
www.oldskoolfantasy.co.uk
dazleeds
old skool raver
old skool raver
Post Thu May 25, 2006 2:01 pm
just looked at mine for a reminder
the pipes from rack to res feed up behind the engine mount then then the 2pipes from res to pump feed over eng mnt to front and under the expansion bottle bottom pipe
looks a bit awkward to feed it but just look at it and have a few tries youll get it right fella
dnt forget to bleed rack with wheels off ground and expect a lot of frothy fluid at first have a rag handy in case it spills over
good luck
this may help
http://www.bmwe30.net/cgi-bin/datacgi/d ... Section=05
eamo
Post Thu May 25, 2006 2:58 pm
but did i here I need a pulley and brackets for the pump. its these parts and there instalaltion that im not sure about
dazleeds
old skool raver
old skool raver
Post Thu May 25, 2006 2:59 pm
yes mate
ya def need need the pulley from a pas car
and also bracket for the pump
sorry assumed you had all this mate
rchadha
Post Thu May 25, 2006 4:57 pm
will a mk1 pas rack fit a facelift which has no pas
dazleeds
old skool raver
old skool raver
Post Thu May 25, 2006 5:00 pm
as far as i know they are the same rack ??
i have fitted a facelift rack straight to an early car before so cant see them being different tbh
