thanks.
prop centre bearing...again!
fuzzy
having gone through the nightmare of removing driveshafts,dropping the exhaust and removing the diff to remove my propshaft(trust me i do,its a ford/bmw custom prop) just 3 months ago to replace the centre bearing i find it has broken again.is there a stronger centre bearing from another model that fits or an uprated version? i understand that the muppet that made the prop up probably hasnt balanced it causing this
,so im also on the look out for a local-ish company that can balance my prop and cut and weld in a new joint so in future i dont have to remove half the back end to get the prop off.can anyone recomend anyone in the edinburgh/glasgow area?
thanks.
thanks.
