Rusty Door connections. Electrics
gazm3
Post Sat May 20, 2006 10:02 pm
Is this a new loom or an easier repair. Seems to be a common fault.
Anyone repaired this problem?. Cost of a new cluster?.
Cheers Gareth.
Post Sat May 20, 2006 10:52 pm
Pins and sockets are available seperately to replace corroded ones, or simply hard wire the affected pins through the hole provided in the plug and socket
Normally only the permanent live (central locking) pins and the ignition live (mirror) pins are affected. The former can be removed permanently (red/black wires!) and the latter can be repaired.
gazm3
Post Sat May 20, 2006 11:06 pm
I think its the drivers window Brian, will this pose any major problems mate?.
Post Sat May 20, 2006 11:11 pm
If it's just the window motor, then feed a twin wire through the rubber boot and the hole in thee plug and socket into the door to the motor.
This is how dealer retrofitted electric windows are wired as standard.
DaveD
E30Zone Wiki Specialist
Post Sun May 21, 2006 8:14 pm
I have just done this and found that new pins are expensive and the dealers dont know which ones they are..i went to my local scrappers (Quarry motors sheffield) and got a like new one with adout 6"of wire and replaced the old corroded one with this ...all the wires have the corresponding colours.. and bullet conncted them...the famous red/black wire i hardwired through the middle ...the whole job cost me £5 and 2 hours
