HELP..windsceen wipers and washer stuck on
DaveD
- E30Zone Wiki Specialist
.windsceen wipers and washer stuck on on,, any quick cure or is it fuse out and new switch...
Does the switch feel faulty?
Pull the big rectangular "relay" out of the fusebox.
- Homo Hair
i had this.. it cured itself tho
DaveD
forgot it worked thru a relay...the switch feels ok so will go and get a new relay,,,,,
I'm not saying the relay is faulty! Pull it out, tell us what difference it makes, and what the column switch does then.DaveD wrote:forgot it worked thru a relay...the switch feels ok so will go and get a new relay,,,,,
DaveD
cured!! it turned out nothing was faulty,,,,one of the blade fuses had fallen out of the fusebox lid and jammed under the relay shorting it out
