Hi,
When idling particularly if warm the engine seems to give a rattly sound as if something is loose....is this anything to worry about??? cheers
Noisy Engine...Any ideas??
Sure it's engine, and not gearbox?
ed325i
Does it stop when you put the clutch pedal down ?
ED
ED
domross
Thanks guys will try that out....it'll doubtless be whichever is most expensive to fix....
domross
Hi again , Yes Ed the noise does go when the clutch is depressed....anything serious?????
Think you may be just describing typical E30 gearbox idler rattle.
If this is what it is, then it's nothing to worry about at all.
domross
excellent news....ta very much Brian
