Hello,
Hopefully going to tackle the sump gasket this weekend. Should the oil leak indeed turnout to be the rear crankshaft seal, is the flywheel going to have to come off in order for it to be replaced?
Thanks,
Scott
Flywheel off for rear crankshaft seal?
Ant
- Retired Team Member
- Contact:
Yes mate, the seal itself is in a bolt on housing @ the rear of the block
geting the fly off should present no issues though mate, only more nuts and bolts
Email FTW
