Camber Questions!!!
Sooty
Post Tue May 09, 2006 9:52 pm
The E46 cab top mounts (for rear shocks) are an upgrade and won't do anything to help the camber problem. It's just better quality than original plus there's a reinforcing plate that helps spread the load.
It's a worthwhile mod to do though.
The rear camber problem can be corrected with either offset bushes or a camber correction kit from somewhere like Ireland Engineering in the States.
IIRC, offset bushes are E30 M3 ones that fit in place of the standard ones but can be a bit fiddly to ensure you get the angles right.
The correction kit involves welding plates on to the rear subframe and using special offset bolts that can be adjusted in-situ without removing bushes to change camber angles.
I've just received one of these kits from the States (cost me nearly £100) and will be having a go at it in the next couple of weeks.
HTH
Iain S
ed325i
Post Wed May 10, 2006 8:40 am
