spring help (60mm)
fozzy325is
Post Mon May 08, 2006 5:46 pm
will springs off a cab (318) be ok to put on a 316? or are cab springs not the came as e30 coupe? thanks any help mucho apreciated!
Ziggy
Post Mon May 08, 2006 5:55 pm
Fronts should be ok, but the cab rears will have been designed to cope with the extra weight, so they won't sit as low on a coupe (probably a good thing!) :thumb:
fozzy325is
Post Mon May 08, 2006 6:05 pm
gud idea 2 fit then?
