iv given in!!!!!!!!
e30bmlover
Ac Schnitzer prophet
Post Mon May 08, 2006 12:12 pm
right iv thrown in the towel and my hunt for more power may be over, im going to look at a 325i (G reg) 2 door, dolphin grey at the weekend. they guy says its done 121,000 and has all the service stamps, he says its clean for its year and no rust. can someone give me some pointers for when i go and look at it. i know about the boot lineing and looking at the rear arches, but my knowledge is a bit limited. can u tell if its been thrashed? any help would be great.
ClemQjeronimo
Post Mon May 08, 2006 12:28 pm
just a few things i look for,
- worn seat/gear stick/ steering wheel. if its done 120000miles seat and gear stick might be a little worn but steering wheel should be ok,
- obvously smoke and steam coming out of the exhaust
- take it for a spin, if it doesnt brake in a straight line then somethings bent (maybe in an accident) so be weary
-noises from box/bushes/diff
-difficult to tell if its been thrashed but you can usually tell from who drives it. young guy etc then probably, older enthusiast, probably but in measured doses.
-check all the fluid levels. oil filler cap
-most essential is regular servicing and inspection.
e30bmlover
Post Mon May 08, 2006 12:31 pm
nice one mate. will have a good look.
ClemQjeronimo
Post Mon May 08, 2006 12:34 pm
thats cool.
i find just be clinical and dont let the guy sweet talk you. you'll quickly get the feeling about whether this is a good motor or a lemon. good luck!
HartgeH27
Post Mon May 08, 2006 12:51 pm
Placey wrote a good guide which can be found here:
http://www.e30zone.co.uk/modules.php?na ... ic&t=22543
Globulator
Post Mon May 08, 2006 1:46 pm
ClemQjeronimo wrote:-check all the fluid levels. oil filler cap
When you've got the oil filler cap off check the valvework - it should look like new (shiny, silver) if it has been well serviced. With a finger try to get some gunk of the inside/top of the rocker cover - there should be none. Tiny angled mirrors and a torch is useful too. This is a very quick, blunt check.
1986 325i 'vert, funk louder than standard.
"No Mr Bond, I expect you to tell me why your 4 litre, 282bhp sports car can't outrun some lardy old Mercs.."
Audio & electronic software: http://www.cutestudio.net
Geoff
Post Mon May 08, 2006 1:54 pm
Check for:-
- DAMP UNDER ALL AREAS OF CARPET, ESPECIALLY FRONT FOOTWELLS
- PLAY IN STEERING. ROCK THE FRONT WHEELS TOWARDS YOU INDIVIDUALLY, SHOULDNT MOVE AT ALL.
- LOW SPEED DRIVING, WACK IT IN FIFTH AT 30MPH SEE IF IT JUDDERS. COULD BE DIFF BUSH / PROP DOUGHNUT GONE.
- CHECK DISCS BY FEELING FOR LIP ON THEM. IF ITS REALLY PROMINENT THEN THEY'LL NEED CHANGING.
- MAKE SURE IT DOESNT POP OUT OF GEAR, MEANS WORN SELECTOR FORK. MINE WENT IN 3RD IN MY LAST CAR WHEN YOU ACCELERATE THEN BACK OFF IT WOULD POP OUT.
Erm and thats about it really. apart from the other areas to which you are aware of. Best if luck.
