I don't normally believe in coincidence but . . .
Fitted a new flasher relay from ECP & it all worked fine. However, within 2 days my battery was dead. Enough juice to light up the dash but not even a click from the starter.
Charged it up overnight & checked each cell's specific gravity. All except one were fair to good. Bad cell looked pretty dead.
Connected it back up & it would slowly turn the engine over but no hint of a spark. Tried jumping it & fired straight off. Took it for a short run but couple hours later dead again.
Have I got a short somewhere or has my battery given up the ghost with no warning? It looks like it may very well be the original '93 battery.
Two steps forward & one step back
AndyTouring
Only way to tell if you have a battery drain is to connect a milliammeter in series with the battery earth lead. If you do a forum search on the subject, you will find a method I describe that doesn't lose radio codes, etc.
30mA is normal, 60mA normal if you have a power hungry alarm, 100mA is too much.
If this is the original battery, then you should br looking at contacting the Guiness Book of Records!
