Power steering.....
kam-325i
Is there any way of making the power steering less "Powered".
Mine works ok, but it seems that when driving at 70 -80Mph, the steering is just a tad to light......
Would a slightly larger pulley (on the pump) help out ?
Simon
No idea about the pulley, but you could leave all the air out of your tyres as a temp measure!?
Joking aside, are the tyre pressures OK?
kam-325i
Tyre pressures are ok, 30Psi 205/55/16.
Even when stationary, the steering is light, i would not mind losing a bit of the help.
bottlecapE30
the only ways i can think of are 1) remove the belt from the power steering pump 2) go to a wider wheel/ tire in the front
I don't think there is much else you can do..... unless someone knows of a lower pressure pump that will bolt up?
1987 2.7l e30 m20b27 supercharging
1991 3.5l e30 m30b35 it is dead so sad
1985 3.5l e23 m30b35
You can get 'underdriven' pullies, these are a smaller diameter which means the pump will be turning less, but I doubt it will have any effect on the steering
SCOTT325SE
Off topic - BottlecapE30, what part of Rochester are you from and how old are you? Im wondering if you'd know my buddy Kevin Olsen (Drives a Jeep & rides a Weyless)
SCOTT325SE
ON topic.... Kam, are you sure your tyres are 205/55/16 ?
They should be 15s if you have that size tyre.
Steering effort doesn't vary with engine revs, so a larger pulley wouldn't effect the assistance, except possibly at very low revs, if the pressure then falls below normal.
Isn't there a pressure limiting valve somewhere that could be modified?
stuartgallafant
a smaller diameter pulley would make the pump turn faster. a larger diameter pulley would create less revolutions. try to relate it to the gears on a mountain bike...these are a smaller diameter which means the pump will be turning less
we had an E46 M3 in at work, which the customer wanted the power steering, water pump and i think alternator pulleys changed for larger ones, as "it puts less strain on the engine, meaning you lose less power!" apparently its a mod sold by CA Automotive, but whether it actually works or not im not sure. However, saying that, the steering did have a slightly different feel to it...
stuartgallafant
Underdriven pully= BIGGER
bottlecapE30
I'm just south east of the city limit near Penfield i'm 23. Don't think i Know Kevin Olsen but i do meet a lot of people and I'm bad with namesSCOTT325SE wrote:Off topic - BottlecapE30, what part of Rochester are you from and how old are you? Im wondering if you'd know my buddy Kevin Olsen (Drives a Jeep & rides a Weyless)
SCOTT325SE
no probs mate, was worth a shot from 6000 miles away. lol
i've found 16 inch wheels give more weight to the steering. Try it with 14's now that is light!
bottlecapE30
Does this add weight to the steering because they are wider or is it because they are heavier (unsprung weight)? I ask only because the total diamiter including tire should still be simmiar
