Power Steering Problems
BMWfan5513
i have a 1987 bmw 325i and latly my car has been making sounds when I turn the wheel. i have put fluid back in it and it solves the problem for a day or so. i took it to an auto zone and a guy said that i have water inside it. moisture in the system will break it, but i don't know how he figured that out? i just figured that i had a leak and that i'll fix it when i get back home. is this a normal issue w/ BMW's? i'm just wondering if there has been any recalls or any way i can fix this problem w/o buying a whole new pwer steering system?
johnono
drain, flush system. find leak in the process. replace the faulty item/s. fill and bleed system..
i havnt got a clue if any of that is correct, but if i have learned anything from the zone, itԚ´s that almost everything can be fixed, and never trust a garage.
p.s welcome dude, u will find all u need on the zone
Steering fluid should be a nice dark red colour. Any other get it changed and flushed right away as Jonoho says, and hope.
SVBMW
Check this thread out, it should help on the flushing bit
http://www.e30zone.co.uk/modules.php?na ... highlight=
Tris
Tris
