Hey all sorry if this has been posted before. Bought some clear side repeaters of ebay and Just wanted to know if anything needs to be crimped at the end of the new wire and where it goes from the indicator.
Many thanks
Clear Side Repeaters Fitting
julianm40
appletree
i fitted some last week end, easy they came with a huge length of cable that i chopped off till there was about 2inch left then used a soldering iron to melt the old indicator wire off the old indicator, then used some conecting block to join them an some heat shrink to seal them, as i wanted to be able to remove them if the i needed to. very easy job, you could just use some crip turminals to join them if you have any.
julianm40
Ummm, i just used leccy tape for now, will redo it properly when ive got the time!
