M50 Conversion Shopping List.
Dan320is
Post Thu Apr 20, 2006 3:15 pm
There comes a time when a standard M20 lump isn't enough, so I'm going to put an M50 into my 325i Touring Auto, while I'm doing this I'm going to convert the car to manual aswell.
Have any of you guys got a list of what exact parts I will need for the engine conversion? What bits I need and off what car?
I have done a manual conversion before so that bit will be easy this time. I want to get all this done before I strip it out for the roll cage and order my new wheels.
Hopefully Stevetigger will be along shortly as he has just done/doing the conversion in his cab'.
Thanks in advance guys. winkeye
stevetigger
Post Thu Apr 20, 2006 3:33 pm
Me :D
Yep, just over half way through!
Ive found its the diff and prop thats been the slow part in the conversion!
E30 M3 diff and Prop.
Electric Fan
E34 Engine and box.
Golf brake servo and Audi M/C
E36 alloy Engine mounts
E34 rubber mounts from ECP
Accelarator cable from a Z3 2.8
M20 Temp sender (brown)
I used my 318 rad
Im sure theres more on the list, just cant think at the mo!
bigpimpin
Post Thu Apr 20, 2006 3:49 pm
Steve,
you mention the Audi Brake Master Cylinder, Is that the same one as Buster has used?
I have the MK2 Golf 1.3 Brake Servo but am still hunting for a M/C.
Buster mentioned it had to have 25zv cast into it and come from a >1990 Audi 100 or 200 turbo. If this is the same one do you have a ECP or GSF part number?
I dont want to use the one that needs a bit of a cut bolt to make up the length! :cry:
www.m3touring.com
stevetigger
Post Thu Apr 20, 2006 3:53 pm
I found my Audi M/C on ebay £7
Im using the Audi 80 M/C thats 23mm
Buster is using the 25mm for better stopping power!
tbmw
Post Thu Apr 20, 2006 8:07 pm
how much does the shopping list differ if i was goin for the s50
engine obviously but what else?
A clear conscience is a sign of a bad memory
