320 speedo won't work at all
heraldohiggens
Post Mon Apr 17, 2006 7:27 pm
Hello there
Ive just put a replacement working cluster in2 this 1990 320
hoping it would sort the speedo, no joy. All the other dials are working.
What else should I be looking at, there's a speedo sensor in there somewhere, what's the crack with that?
Martinaston
Post Mon Apr 17, 2006 8:00 pm
Check the wire coming out the back of the diff, normally goes brittle and snaps. check it for continuitty between the diff and the socket under the back seat.
There is NO nucleus.
Post Mon Apr 17, 2006 10:18 pm
Martinaston wrote:Check the wire coming out the back of the diff, normally goes brittle and snaps. check it for continuitty between the diff and the socket under the back seat.
It's the copper inside the wire that breaks, not the sheath, so it won't be obvious from the outside.
Pull the individual wires gently. If they stretch, they are broken inside.
