hi,ive tested my electric aerial by putting the earth on the - and the red and white wire on the + all i get is a click from inside,is it buggered?!! any ideas?
Tel
electric aerial
smithy318i
the click is probably a relay inside the unit. if it doesnt go up with all 3 wires connceted, its buggered.
probably fixable with the right parts. may be a fried motor, or a loose/broken contact on the relay.
i would have it in bits by now.
Strawb
i have fitted a new sterio in to my car it has an electric arial which wire do i need to connect to the sterio's arial activation wire?
BMW 320i SE Coupe
http://www.gorilla-x.com/jpg/at_ch.jpg
smithy318i
not the red or black wires, the other one.
Strawb
is this around the back of the sterio ? im a bit confusedsmithy318i wrote:not the red or black wires, the other one.
BMW 320i SE Coupe
