That tells me its earthing out somwhere but i havent got a clue where to start looking, my dad eaven says it could be a faulty bulb
all ideas are welcom
cheers matt
Dimmer switch is in the "earth" circuit of the panel lamps, so a short to earth here would only make the lamps light at full brightness.gazjon wrote:A few surgestions that might help:
Try adjusting/disconnecting the dash light dimmer switch, these are variable resistors and it common that the contacts can short out .
Check that the heater control cables are not rubbing on the loom, if they are still to opperate this could indicate something getting trapped on them.
Hope this helps
