Seatbacks
coldo
Post Thu Apr 13, 2006 12:39 am
Anyone know much about the seatbacks in there E30?
Particularly interested in the "comfort" seats.
My drivers seat has developed a "lean" to the left :? nothing drastic, but its a problem i wouldnt like to have to be honest!
Had the seat out yesterday, but couldnt really see many bolts etc.. that i could adjust, im presuming its inside the seatback that need slooked at?
Anyone had a similar problem? How did you fix it?
Cheers :cool:
mrLEE30
Post Thu Apr 13, 2006 5:33 am
mate i got a great article on repairing seats, covers everything. PM me with an email address and i will send it to you (the website is now down so i have it saved as a file). otherwise try
http://www.r3vlimited.com/Tech/sportseats.htm
mrlee
DaveD
E30Zone Wiki Specialist
Post Thu Apr 13, 2006 8:04 am
I had a similar problem on the fiat coupe and it turned out that the seat frame had broken and need welding...my upholsterer says its quite common
have a look on realoem for the seat frame diagram
best of luck
Simon
Post Thu Apr 13, 2006 8:15 am
When the seat develops a lean, it's normally the weld that has broken, it can be repaired, but requires some stripping down, and is quite fiddly.
Another common problem is when the lower mount screw comes loose, but this doesn't cause a lean, just the back rest becoming loose.
