HELP! water behind passengers seat..
N4SBM
is it coming from the window, yesterday i lifted the carpet to find its drenched, this is new, what can i do??
Hyperion
what body do u have, 2dr,4dr, convertable, touring?
dazleeds
- old skool raver
rear window seal
or poss the round plate in the rear footwell leaking
its a common e30 wet spot sadly
www.oldskoolfantasy.co.uk
Hoggy
behind the seats in the floor pans are some compressed fibre discs which fill in holes in the floor,check that these haven't rotted through before you do anything drastic, mine rotted and i just cut a couple of new discs out of aluminium and fastened them in with mastic and pop rivets,hope it gets you sorted,Boss
N4SBM
sorry for the late reply guys, its for a convertible..
N4SBM
will check if its the footwell, hope its an easy fix, thanks alot guys!!
not 100% on this one, as know little about cabs, but sure i'd seen someone with problems like this before and it traced back to the hood storage compartment being full of water so check there too dude.
