help!
bmpaul
Post Sun Apr 09, 2006 1:38 pm
hi my m50 e34 525i has decided to suddenly stop when i was driving it it gave no warning and just died on me. it cranks but no start. can anyone enlighten me?
thanks paul
Widge
Post Sun Apr 09, 2006 1:50 pm
Sounds like it could be cause by loads of things from the ECu to the fuel pump. I can't really offer a better opinion without more information. I would say however that I have heard of this happening in the past abeit not on M50s and it has turned out to be the crank sensor.
Sooty
Post Sun Apr 09, 2006 2:21 pm
Fuel pump fuse or relay?
Iain S.
Post Sun Apr 09, 2006 2:26 pm
need to give more info mate
pull a plug out and crank it to see if you've got a spark. Check if it is getting fuel too
Post Sun Apr 09, 2006 2:48 pm
E30BeemerLad wrote:need to give more info mate
Not quite so easy on a M50 as on a M20. Smell the exhaust for petrol.
You need fuel, spark and compression for an engine to run. Lack of compession is unlikely, so you have to work out which of the other two is missing (or both).
Post Sun Apr 09, 2006 3:48 pm
Is that due to coil packs Brian?
Post Sun Apr 09, 2006 3:55 pm
E30BeemerLad wrote:[
Yes, you'll have to take the covers off, undo a coil pack, take out a plug, stick it in the coil pack, earth the coil pack metalwork and make sure the plug body is earthed.
Don't skimp on any of this, as I think it's fairly easy to spike the ECU.
bmpaul
Post Mon Apr 10, 2006 4:29 pm
its ok lads, after a bit of detective work and pulling various fuel hoses off i had a hunch that it was not getting any petrol i found that the fuel pump had died so i have just replaced it and it is going!!!
