Fitting H&R 35mm front springs.....
e30_Turbo
Boost Junkie
Post Sat Apr 08, 2006 11:29 pm
Hello all,
Does anyone know wether the H&R 35mm kit requires springs compressors to fit?
The rears needed some help but not suire about the fronts......anyone know???
Thanks, Mark.
chu346
Post Sun Apr 09, 2006 1:39 am
Definately
e30_Turbo
Boost Junkie
Post Sun Apr 09, 2006 1:50 am
cool, will obtain some asap then.
The rears were ok, bit tight but they are in and sitting were they should.
Thanks for your help, Mark.
Dan318-is
Post Sun Apr 09, 2006 1:51 am
if you undo the anti roll bar link bolt as well as the 19mm strut bolt they slip in an out without even a tug
chu346
Post Sun Apr 09, 2006 2:00 am
Dan318-is
Post Sun Apr 09, 2006 11:56 am
sorry, was talking about the rears; he said they were tight thats all; i did my 35mm onmy own it was a doddle if the correct bolts were removed
