help how to identify a e30 aplina engine plus spec
MOODY
if it's the whole engine then just fit it and bin the 2.0 lump. U want the rad or a normal 2.5 rad too
it should have
black inlet manifold and rocker cover
also a 4 digit stamping on the head at the front of the engine under the inlet manifold. Hard to see too
Also should have C2 2.7 and a number begining with MA then some digits on the block, also quite hard to see.
If u get the engine then u will need a 2.5 gearbox and diff to cope with the extra power
Also will need a rear disk conversion off a 318iS or 325i to make it stop!
The alpina ECU will help, but u could just use a 2.5 ECU and chip it
HTH should answer all your questions from your PM to
it should have
MOODY
