What do people think
HartgeH27
Break - buy 325 ...........not worth the hassle of rebuilding. Money you get from breaking will offset the cost of a decent 325.
m3ben05
m3ben05
Turbo-Brown
- Boost Junkie
Could bung a 3.5 in it for good measure
Not teaching you to suck eggs or anything, but one car's pretty much the same as another and anything you know about Vauxhall's will to a greater or lesser degree be applicable to your E30.
Would be a shame to scrap that M3 rep shell for the sake of an engine swap too!
stevetigger
I dont know shit about engine conversions but look at me! Mbloody50 going in. It will be easy to change from a 323i to a 325i m20, or go the full hog and get a bloody M50 in there
Go on, ive convinced two other zoners to do it!
m3ben05
hammoj28
That car does look very nice.
24v tech2
stevetigger
Im sure there's loads of people that would help!
Get yourself an engine and put up a wanted "help" post and watch them come flocking.
Widge
You'll need to do somthing about those front wings won't you mate?? The engine swap should be easy, especially if you have a donor for all the little fried bits. Hire a trailer and borrow you long lost uncles pick up truck, you got yow self a convoy!
Widge
Go for the 323 mate, then at a later date you can go silly and do a cam and throttle bodies so it will actually look more M3 ish under the bonnet, or more like a racing/track car, would sound sweet too.
hammoj28
323i was meant to be quite quick? Glad your keeping it.
24v tech2
hammoj28
Yeah my mates dad insists that the 323i's were quicker than the 325i's. haven't a clue wether this is true though.
24v tech2
stevetigger
I think its the gearing that makes them quicker to 60 but not top end, I could only get 125 out of my old 323i
hammoj28
Ahhh, i though it must be something to do with that.
24v tech2
Widge
Short shift conversion for 1
The just give it a really good service, timing belt, set tappets and a rocker cover gasket, oil change, Box and diff oil, clean the icv and TB - BBTB would be a really good mod - and maybe some new hoses.
mrLEE30
you will also need to change your sig .. old beemers dont die they just set on fire!!!
the car looks good, go for the engine swap and fix the wing.... better the devil you know and all that!
mrlee
mrlee
gary
Tng I'm replacing an offside wing on my Sport Evo. It has a small bit of rust at the bottom of it right on the arch. is this any good to you
Widge
Go BBTB, even better!!!, you'll need to play with the manifold though if it's going to actually make any difference. You could just got to a 2.5 inlet maniflold. Chip would be good too, although I'm sketchy how that would work on a 323... Ant???Tng21 wrote:short shift good idea, daz said lightened flywheel, 325i tb, any other simple little things people can suggest?
dazleeds
- old skool raver
its all coming together now
tng asked me about different injectors etc but i have no idea
anyone??
not sure whats poss with chips on the l jetronic mate??
www.oldskoolfantasy.co.uk
Widge
Wouldn't bother with changing the injectors mate unless you went to ITB's and mapping, um as for the 325 inlet manifold you'd have to port the head to match otherwise ther would be a step which would make it all pointless, depends how far you want to go - you could fit a cam. Depends if you want to get it back on the road asap, or if you can take the time whils the shell is being sprayed to do the engine. E36 steering rack???
dazleeds
- old skool raver
you could always go a bit further
i had a similar plan for this engine to go into my grey 320i
Iain temple had some very good ideas for upping the power and making it into a 323 that would rag 325s
it may be worth asking him his oppinions
my plans did involve a cam change and 3 angle grinds on the valves etc
but would have put pout some nice power
