Map reading light
badnan
would a rear view mirror with map reading light retro fit my 316i 93 L reg touring.
E30WEZ
Fitted one to mine ok make sure it has the adjuster that goes on to the windscreen to stop the vibration as they weight more.I wired mine to the +/- on the interior light so it works with the ingnition off the hardest part is routing the 2 wire's across the roof.
WEZ
6potWil6pot
Howd you feed it up from the interior light? Put the cable on a coathanger and fiddle about a bit?
