What are these wires? (M20/Motronic)
JazzMan
Post Wed Mar 29, 2006 2:37 pm
On the engine loom to car loom connector what do these pins do? :
8 yellow with white stripe
9 black
14 blue with yellow stripe
15 black with green stripe
I've figured the rest out from a diagram but those are not labelled :mad:
mrLEE30
Post Wed Mar 29, 2006 3:45 pm
not sure if this will help but for the diagnostic plug
pin 8 white/green
DME Control/Idle control
pin 9 black
tachometer
pin 14 black/white
obc speedo signal
pin 15 black/green
Strarter/unload relay
i realise the colours are not all the same but i hope you can trace the wires and solve on or two!!!
mrlee
JazzMan
Post Wed Mar 29, 2006 6:20 pm
Thank you :D
kam-325i
Post Thu Mar 30, 2006 4:58 pm
JazzMan wrote:On the engine loom to car loom connector what do these pins do? :
9 black
Try this
http://addissimo.com/Engine/OEMwiring/Wiring.html
8 = DME Cont/Idle Control
9 = Tachometer
14 = Speedometer Signal(OBC)
15 = Starter/Unloader Relay
