Im going to do the m30 conversion on my recent purchase from ebay.
Im going to use e32 735i & switchable box.
What mounts and engine position should i use ?
M30 Auto & Engine Position
gareth
i'd suggest trying position 2.5 as a starting point. this will (just) fit in at the front and give you the maximum room at the back.
however.... from memory the E32 autobox is HUGE and you'll probably have to cut loads out of the transmission tunnel.
why not go manual?
why not go manual?
m-dtech
- Unapproved Trader caution
its the same box used on the 325igareth wrote:i'd suggest trying position 2.5 as a starting point. this will (just) fit in at the front and give you the maximum room at the back.
why not go manual?
gareth
really? it looks a load bigger than the manual box.
E34 M30 manual box:
E32 M30 autobox:
can't remember it being the switchable one though...
E34 M30 manual box:
E32 M30 autobox:
m-dtech
yeah thats about right, that looks like a non switchable box.
should fit fine
should fit fine
gareth
that's ok then. the one i took out was massive compared to the manual box.
why go auto though? i'd be a lot happier with the control that a manual gives!
m-dtech
switchable sports auto, good for drifting.
and would mean converting my car to manual.
auto is good n lazy
auto is good n lazy
gareth
horses for courses i suppose.
would be a first maybe?
