Over the last few days it seems to have got hard to engage gears when driving, and the cluych has been very low.
I've gone to go out this morning, and cant get any gears except fifth, and occasionally fourth, this is with the engine running.
With the engine switched off, I can select all gears.
Any ideas?
Gearbox/Clutch Problems
less2303
Ziggy
How's the fluid level?
less2303
Will check now!
less2303
Clutch fluid fine....
Ziggy
Quite possibly the master cylinder then... I'd change the slave too, because fitting a new master may well cause it to fail anyway
