hi Guys in a bid to clean up the new 325ise i cleaned under the engine bay but i may have got some water in the fuse box
now i have striped it down cleaned with WD40 but
lost me indicators and hazard lights
on checking fuses i have no power to the following fuses
1
2
7
11
13
14
15
29
30
any ideas
i have changed flasher
thanks dirt
oh dear i think iv broke it (lots of fuses no power)
ukdirtyboy
ukdirtyboy
and the mad thing is fues 4 has power and that is flashers and car runs and lights work bar the flasher lol
Water in the fusebox shouldn't cause any problems at all , except to the wiper control module. Everything else in there would happily work under water!
Any water in the fusebox will drain down inrto the cabin behind the glovebox anyway.
Just leave the lid off and let it dry - keep the WD40 for rusty nuts!!
Not quite sure what you mean by no power to those fuses. With ignition off, only fuses 21 to 28 inclusive should be live.
ukdirtyboy
with the engine running
1
2
7
11
13
14
15
29
30
have no power to the top of the fuses on the test points
1
2
7
11
13
14
15
29
30
None of these, except one, should have power with the engine running.
The exception is 11, which is fuel pump, and I assure you, that with no power on 11, your engine isn't runnung!
Do the hazards work? (with flasher relay on the steering column in place)ukdirtyboy wrote:and the mad thing is fues 4 has power and that is flashers and car runs and lights work bar the flasher lol
Just re-read OP!. No hazards either.
Indicators run off fuse 4, hazards off fuse 24, and are entirely seperate untill they reach the back of the hazard light switch itself.
Most common cause of indicator problems affecting both sides equally is the hazard light switch.
Pull the switch out, and check for permanent 12V+ on the red/white wire on pin 3 and ignition 12V+ on pin 1 (purple/grey).
ukdirtyboy
sorted thanks for that
mad the hazard switch half on half off was stopping turn light
under the fuses box has bee rewired but all seems to work now
god its cold outside snowing and you know what that means......... yes the wife going to take the keys off me so i cant go out in the snow and have fun fun fun
