3.5 Conversion
m-dtech
Unapproved Trader caution
Post Sat Mar 11, 2006 7:50 pm
Possibly going to be the owner of an E32 735i Auto.
What do i need to convert my E30 to a 335i Manual.
What engine mounts ?
What exhaust ?
Can those who have done the conversion please give me some advice ?
ed325i
Post Sat Mar 11, 2006 8:08 pm
Hi, I would do a search on the zone or go to www.e30.de
ED
bmw335isturbo
Post Sun Mar 12, 2006 9:05 am
m-dtech wrote:Possibly going to be the owner of an E32 735i Auto.
What exhaust ?
Ok hate to tell you this but engine mounts you would be better off making them your self same with the exhaust.
My freind and I have built ower own I did the e28 and he used the e34 3.5l
but mine was a lot faster it took me a year 2:79LSD and a getrag265 tranny 17" wheels.
When you proceed with this project it is not as easy as just bolting every thang together, it takes A lot of fabracating But i must say the car is really fun.
charlE30
Post Sun Mar 12, 2006 6:10 pm
What exhaust ?
You need a manual box, clutch and flywheel. A manual ECU and loom although I think Toby doctered the auto loom to work.
Engine mounts from www.e30.de or karan on the zone.
You can use an E30 M3 exhaust but will need to get a flange made to mate with exhaust system or bodge a standard 325i as a tempory measure.
Good sites for info are:
http://homepage.ntlworld.com/a.law47/33 ... uring.html
http://www.tobyunna.com/
http://www.e30.de/
http://www.jaredsquires.com/ndp/335i/
Also worth doing a search on M30 conversions on the zone :thumb:
Good luck mate, hopefully start mine soon :cool:
BMW F31 335d xdrive
stevetigger
Post Sun Mar 12, 2006 6:25 pm
charlE30 wrote:hopefully start mine soon
Not hopefully, you will start it soon! winkeye
gareth
Post Sun Mar 12, 2006 10:51 pm
charlE30 wrote:You need a manual ECU and loom
a common misconception. both toby_unna and i used the E32 auto loom and ECU. there are NO problems with it. a few wires will need extending (coil) and a few small alterations need doing to the main engine plug to make the unloader relays work, also a small mod to make the economy gauge work. i think this is still the case with the manual loom though.
look here for info on the connector mods you'll need, both are covered:
http://www.e30zone.co.uk/modules.php?na ... ght=wiring
charlE30 wrote:You can use an E30 M3 exhaust but will need to get a flange made to mate with exhaust system or bodge a standard 325i as a tempory measure.
i'd use the M3 system. i have the profile for a flange saved as a CAD file to pass to a water or laser cutting company. pm me if you want a copy.
i've just done it and it's well worth doing.
my thread is here: http://www.e30zone.co.uk/modules.php?na ... ic&t=22989 it may save you a few questions.
bottlecapE30
Post Wed Mar 15, 2006 4:55 am
funny i own one of these and i rarely look under the hood as im scared to see how it was done. it is bound to need some work this summer as it now has 347K miles. seems to drive okay
best of luck with the swap
1987 2.7l e30 m20b27 supercharging
1991 3.5l e30 m30b35 it is dead so sad
1985 3.5l e23 m30b35
