Well im half way thru installing a genuine 3.5 alpina B10 engine into my E30 325i. The engine came from a accident damed E34 B10 my mate located at a scrappy.
One thing i need help with at the moment is the oil cooler.......... Have other guys on here with M30 3.5 engines kept the cooler or simply done away with it?
il post up pics of the engine strip and rebuild progress within the next few days. should be a pretty quick car as power on this Alpina engine is a fair bit up on the standard 3.5 that alot of you guiys have already fitted
Part way thru my alpina B10 3.5 conversion
gareth
apparently the E28 M535i oil cooler setup fits.
also the E30 M3 one can be used iirc. check out e30.de
