320 afm into 325
oze30
Post Fri Mar 10, 2006 5:48 pm
can you use a 320 AFM on a 325 engine?
It seems to work out quite well, lost the hunting idle, but just not sure it's going to work properly.. Think I got a flat spot somewhere too
Kamaloff
Post Sat Mar 11, 2006 11:53 am
Why oh why would you want to use an AFM designed for a smaller-displacement motor?
oze30
Post Sun Mar 12, 2006 9:47 pm
because i know it works, and the plastic cover on the 325 has come off.. so not sure if they the same or not. It seems to work, but just want to make sure they do.. else i'll have to change them over again!
oze30
Post Tue Mar 14, 2006 7:48 pm
right.. changed the afm back to the 325 one.. and now have the hunting idle again.. what could it be?? Should i change back to the 320.. it works and idles fine??
