Draining the fuel
Grantley
Does anyone know a easy and not too messy way of draining most of the fuel out of the tank (spare me the jokes about driving it
), any advice appreciated
Ant
- Retired Team Member
take the fuel feed hose off @ the fuel rail, short the fuel pump relay socket so the pump runs 24/7 and use that to pump her out fella.
tried and tested btw, 100% working
Email FTW
Chris-W
Or you could use the drain plug on the tank.
If your brave enoughChris-W wrote:Or you could use the drain plug on the tank.
Grantley
Thanks for the advice chaps, dam british of you !
