335i transmission output flange
Patrick335i
Post Tue Mar 07, 2006 7:41 am
Has anyone experience with the Getrag 260 transmission of a E32 until 09/87? Here the output flange 23211228038 is assembled. I would like to use the newer output flange 23211203061 until 09/87, because it is more flat and I can put the center mount of the drive shaft to the right position again.
In addition the transmission output shaft is different:
->09/87:23211228296
09/87->:23211228297
Has anyone put the newer flange 23211203061 or the original 325i to the Getrag 260 ->09/87???
Thanks for your help!
Patrick
Toby_Unna
Boost Junkie
Post Thu Mar 09, 2006 2:19 am
short answer is no
there's 4-5 335 conversions on the zone, but i'm pretty sure none of us has swapped the output flange
Patrick335i
Post Thu Mar 09, 2006 5:18 pm
...so there seems to be just one solution: Garage at 2Ԛ°C :(
Thanks,
Patrick
