E30 Offset Range
danny_j
Post Mon Mar 06, 2006 2:46 pm
When fitting Bigger wheels.
What kind of Offset Range should i look for?
Ziggy
Post Mon Mar 06, 2006 3:08 pm
Depends how big! 15" BBS are ET24, so that's a good place to start... After that you need to just look at how wide the wheel / tyre is, work out how close it's gonna be to the strut or arch & choose an offset accordingly. :thumb:
danny_j
Post Mon Mar 06, 2006 3:17 pm
Thanks mate
My 17s are ET37 i think :mad:
I know a guy with 19s on his E30 with a really bizarre offset it's lowered about 120mm as well on coilovers i'll try and get pics
I've just bit the bullet and brought some 18s so i guess i can just sort the arch work out :P
Ziggy
Post Mon Mar 06, 2006 3:21 pm
danny_j wrote:Thanks mate
ET37 will need spacers to sit correctly, & may or may not foul on something (strut / caliper) depending on wheel design / size... Spacers aren't a problem, just get decent ones!
What width are the wheels you've gone for?
sidewaysbm
Post Mon Apr 03, 2006 1:52 pm
what could happen if you dont use spacers?
Gouki
Post Mon Apr 03, 2006 2:12 pm
im running my wheels without spacers and they are I think a 35mm offset. Never had a problem with them in clearance issues except they just sit back into the arches which a set of spacers would cure.
liam012
Post Mon Apr 03, 2006 3:37 pm
et20
rubbing when cornering at speed only
