Exhaust flexi pipes.
Have a 325 for track day abuse. My exhaust is standard bmw, but with the middle box cut out, so it runs from the manifold, straight through to the back box. What keeps happening though is the downpipes keep splitting because of the engine vibration. Has anyone ever fitted flexi pipes (like diesels have) to overcome this problem, as its all i can think of to cure it!! Thanks.
bottlecapE30
When this happens on a track car in the US we cut out a section after the down pipe and add a piece of braided flex pipe this puts a lot less stress on the down pipe because it no longer carrys the weight of the exaust. if you have a lot of engine movment check you motor mounts they could be broken this could be the cause
best of luck
best of luck
1987 2.7l e30 m20b27 supercharging
1991 3.5l e30 m30b35 it is dead so sad
1985 3.5l e23 m30b35
Lloydie38
- Contact:
Just put something similar on my track car so will let you know how I get on - to see my track 325 have a look at my www logo below to link to the site
