replacing manifold
thesaint
Post Thu Mar 02, 2006 9:45 pm
changing the manifold, as it is in 2 peices cra cked all the way around. any tips on doing this, does it go straight on or do i need to remove anything?
1986 325i - Gone. 1993 318i touring, m52 in the planning stages.
kam-325i
Post Thu Mar 02, 2006 9:47 pm
Inlet or exhaust ?
thesaint
Post Thu Mar 02, 2006 10:04 pm
exhaust sorry
koos
Post Thu Mar 02, 2006 10:19 pm
Spray the nuts with some sort of lube, not k.y, wd40 or something, pray that the studs dont break off, replace the studs when the manifold is off, good luck
Ant
Retired Team Member
Retired Team Member
Post Fri Mar 03, 2006 8:39 am
agreed, but spray it for a week or so , daily before attempting removal
also, when the day comes, make sure the engine is warm, if they are seized the heat will aid in removal, obv dont have it scorching hot , burnt fingers are no fun :cry:
koos
Post Sat Mar 04, 2006 4:43 pm
Strangely brake fluid is also a good freeing agent, dont put it on a hot manifold or you will plumes of white smoke !!
Good prank we do at work if someone has done his first head job, pour half a bottle in the exhaust, as soon as it warms up it bellows white smoke out the back, poor bugger shat himself !!!! winkeye
thesaint
Post Sun Mar 05, 2006 4:07 pm
all done with no stiff nuts at all..
Ant
Retired Team Member
Retired Team Member
Post Sun Mar 05, 2006 4:16 pm
well done fella !
thesaint
Post Sun Mar 05, 2006 4:22 pm
incidntly ant, what are the power gains with a chip on a prefacelift 325 compared with a facelift model, chip hopefully hear early next week.. was pulling 170bhp on the dyno as standared.
