E30 imobaliser
Dominitry
Post Thu Mar 02, 2006 5:06 pm
Mate just phoned me now, his L reg 318i has been standing for a while so dead battery, new battery but now he cant get it started because of the imobaliser, i dont have a clue so does anyone else? Didnt even know e30's came with imobalisers lol.
danny_j
Post Thu Mar 02, 2006 5:13 pm
sounds very much the same problem i'm having.
Car had been standing, swapped battery now it won't start!!
Is there even a immobliser on the car as standard? I had a look through couldn't see nothing?
Has he tried bump starting it, i'm a give that go tonight
NH325CAB
Post Thu Mar 02, 2006 5:21 pm
Thats odd cos my battery died a couple of months back and i replaced it but i got no immobiliser problems at all....
...sure its linked?
danny_j
Post Fri Mar 03, 2006 3:22 pm
Just to give you an update bud it was naff all to do with the immboliser was the ignition feed to the DME relay.
If this is to do with the immboliser it will probably cut in between the small yellow and red wire (this is the ignition feed for the dme relay) The red and blue wire or the green and blue wire somewhere down above the gloove box
Hope that helps :)
